  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ross from works auto put one of those hurricane filters on for me yesterday, they are supposed to be a huge improvement over the HKS pod filter. Driving home tonight I'd put my foot down with 12psi of boost and it'd cut out as soon as it hit 12psi, so I dropped it back down to 9psi and it was misfiring bigtime at the top end and didnt feel like it was pulling past 5000rpm... any idea's? think I'll go back to the HKS pod and get a refund.
Originally posted by Sneeza
Ken - did Jeff say anything to you about the car and what i said?? I hope I didn't get you in  trouble
Nah , Jeff wasn't there and as I said , it's not a problem.
Only saw the car you were looking at outside in the dark and rain.
Didn't look too bad but can look at it closer once you decide if it's the one you want.
Cheers
Ken
Lack of restriction causing overboost and lean mixtures.
Seems strange cos I didn't think there would be that much diff between pod filters.
Cheers
Ken
kyles - the sleep over thing was cause you said you were going to bed alone - so ken was gonna come and keep you warm hahaha
I'm not good. I am not doing solo's in the nationals (i haven't got the guts hahah) I am doing three team dances...hard to explain.... Have you seen river dance??
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
