  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ross from works auto put one of those hurricane filters on for me yesterday, they are supposed to be a huge improvement over the HKS pod filter. Driving home tonight I'd put my foot down with 12psi of boost and it'd cut out as soon as it hit 12psi, so I dropped it back down to 9psi and it was misfiring bigtime at the top end and didnt feel like it was pulling past 5000rpm... any idea's? think I'll go back to the HKS pod and get a refund.
Originally posted by Sneeza
Ken - did Jeff say anything to you about the car and what i said?? I hope I didn't get you in  trouble
Nah , Jeff wasn't there and as I said , it's not a problem.
Only saw the car you were looking at outside in the dark and rain.
Didn't look too bad but can look at it closer once you decide if it's the one you want.
Cheers
Ken
Lack of restriction causing overboost and lean mixtures.
Seems strange cos I didn't think there would be that much diff between pod filters.
Cheers
Ken
kyles - the sleep over thing was cause you said you were going to bed alone - so ken was gonna come and keep you warm hahaha
I'm not good. I am not doing solo's in the nationals (i haven't got the guts hahah) I am doing three team dances...hard to explain.... Have you seen river dance??
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
