  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Hi All,
I'm back, but rob77 is coming over cause his car is acting funny, so I may have to disappear for a while:D
See'ya:burnout:
Read back re diagnosis.
BTW , missed you at SST tonight.
Cheers
Ken
Originally posted by skyzerr33
liz will do pm your mobile number
night all must go iron and pack b4 going to work and kylies for the weekend
l8rs
Well you won't need to pack many clothes to stay at Kyles.
Don't forget to come up for air occassionally. Man cannot live by breast ( err I mean bread ) alone.
Cheers
Ken:D
Ken,
Who have you been perving on now? I'm not sure I trust to go down to Collie with you:p
See'ya:burnout:
ohhh trust me.
I don't perv on endangered animals. ( the rare hairy backed blubber whale )
Ewwww !!
Cheers
Ken
Ken - I am planning to check the series II out next week. I really really really like the one at c-red.... but I can't buy it without test driving some others. Andrew really likes the look of the series II - but its my decision hahahah everything in this marriage is my decision. /jks
Originally posted by 33Spec2
aaaaah snez such talent! so let me get this rite you shoota ping pongs out da kling kling at da drop bears so they dont scratch my eyes out? hahahahaha im sure sum tourists will want 2 hire you!:D
Hell , if she can do that , the LOCALS will hire her.:(
Cheers
Ken
that's right Russ - come camping with me I keep you safe with my kling kling..... I love you long time for two fiddy
Paul - I think 10 -14 days... cause they have the disk made up. I can just bull shit and say we need it for a car show and he'll do it. Also did you work out the resizing of the logo for the mens shirts?
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
