  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Hi All,
I'm back, but rob77 is coming over cause his car is acting funny, so I may have to disappear for a while:D
See'ya:burnout:
Read back re diagnosis.
BTW , missed you at SST tonight.
Cheers
Ken
Originally posted by skyzerr33
liz will do pm your mobile number
night all must go iron and pack b4 going to work and kylies for the weekend
l8rs
Well you won't need to pack many clothes to stay at Kyles.
Don't forget to come up for air occassionally. Man cannot live by breast ( err I mean bread ) alone.
Cheers
Ken:D
Ken,
Who have you been perving on now? I'm not sure I trust to go down to Collie with you:p
See'ya:burnout:
ohhh trust me.
I don't perv on endangered animals. ( the rare hairy backed blubber whale )
Ewwww !!
Cheers
Ken
Ken - I am planning to check the series II out next week. I really really really like the one at c-red.... but I can't buy it without test driving some others. Andrew really likes the look of the series II - but its my decision hahahah everything in this marriage is my decision. /jks
Originally posted by 33Spec2
aaaaah snez such talent! so let me get this rite you shoota ping pongs out da kling kling at da drop bears so they dont scratch my eyes out? hahahahaha im sure sum tourists will want 2 hire you!:D
Hell , if she can do that , the LOCALS will hire her.:(
Cheers
Ken
that's right Russ - come camping with me I keep you safe with my kling kling..... I love you long time for two fiddy
Paul - I think 10 -14 days... cause they have the disk made up. I can just bull shit and say we need it for a car show and he'll do it. Also did you work out the resizing of the logo for the mens shirts?
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
