well I drove it and I love it Ken... but I still want to see this one is Malaga.... but yes I am trying to make my decision easier hahahaha
Russ - no the series II is not cheaper.... When could you go out there?? We can meet out there or I will finish work early.. if you feel like being my kling kling bitch and picking me up from wleshpool... (which is pretty much on the way since we have to go up tonkin) hehehehe
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
you got pwpt60secf coming round tomorrow ?
Don't get him pissed and make sure he is at my place 6am Saturday.:D
cheers
Ken
Yep - looks like we're gonna have a bit of a gethering & bbq tomorrow afternoon/evening.
Regular whorers are welcome to join in but please confirm with me beforehand.
Originally posted by Sneeza
Ken - so would you pretty please  with a blow job
WOW...
Oh shit , I thought she was serious, bugger.
Yep , no prob , tell me what day.
Could check it out after work next thursday cos the boys at cred work back then.
Cheers
Ken
Originally posted by Neo
Gday Everyone
I was lost in the la la land of Taka Kaira again.
Great way to go to sleep.
Ahhh , volk te37's , advan rg's , HKS 2530's , Apexi power FC.
Bah , who needs counting sheep.
Cheers
Ken
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
