  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah shouldnt do - i mean where theres to drive in collie haha?! The alcohol does add a couple of extra kilos to the luggage tho haha
I saw the cutest kid while i was up the shop - i hardly ever get clucky but he was such a sweetie - then i came home and heard the baby screaming next door and quickly snapped out of it hahah!
No I couldnt reset the ecu properly, I dont have that key that shuts the siren off and the pin code is so you can disarm the immobiliser and drive the car... anyway, put the HKS pod back on, but now its doing weird shit at the top end. It sounds like a baffled "pop pop pop" noise and is hesitating (under 100% throttle, if I dont floor it it goes ok) ... it could be leaning out now :) *sigh* me give up.
    • Would be easier to just run the RB25DET gearbox, all you would need to do is have the tail shaft / prop shaft shortened. S15 uses the rear ABS diff sensor for the dash speedo, so you can skip using the gearbox speed sensor.
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
