  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
well im off guys n girls
*kisses Paul*
*hugs everyone*
Sweet dreams everybody :angel:
BYE
Bye Niz.
Hmm kisses for pwpt60secf.
Is there something going on I don't know about?
Cheers
alszcheimers
Ken
paul - no joke.. hope u like bombay saphire.. i wanna be there to see u finish the bottle tho.. :)
aidwin - tune is much better.. heaps stronger down lower - still get a little surge tho - i've got suspicions it could be faulty wiring with the itc.. tune needs fixing cause can't run more than 0.65bar at the moment... didn't get a chance to ask bout the power fc - he was too busy to even let me pay him when i picked the car up.. all for free so far.. hehehe :(
As per my post I'm doing a few cosmetic things now, like I've had a set of side skirts since november last year that were meant to be put on before I went to the UK in december that still arnt on yet :( Plus paul has some rims for me, then I think a catch can after seeing the oil in the intake manifold today and a ogura flywheel as well :)
Originally posted by gtrken
Bye Niz.
Cheers
alszcheimers
Ken
Yeah i know - they werent even appreciated so it'll be the last time i do that haha
I'll ride with anyone who wants to give me a lift - beats walking anyway haha
**gone for good now** Later peeps!
paul - sweet... zanda will probably be wanting to come too... i supose we can't have too many people otherwise accomodation will be hard to find...
as for drinking - i'm sure i'd be up for that.. would like any chance to drink u all under the table.. :(
aidwin - cooler is on the cards.. some guy got 275rwhp with the same setup as me, well close to it, cept he had a front mount.. so for an extra 25hp it could well be worth it.. me don't want to sacrifice low down power tho....
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
