  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
well im off guys n girls
*kisses Paul*
*hugs everyone*
Sweet dreams everybody :angel:
BYE
Bye Niz.
Hmm kisses for pwpt60secf.
Is there something going on I don't know about?
Cheers
alszcheimers
Ken
paul - no joke.. hope u like bombay saphire.. i wanna be there to see u finish the bottle tho.. :)
aidwin - tune is much better.. heaps stronger down lower - still get a little surge tho - i've got suspicions it could be faulty wiring with the itc.. tune needs fixing cause can't run more than 0.65bar at the moment... didn't get a chance to ask bout the power fc - he was too busy to even let me pay him when i picked the car up.. all for free so far.. hehehe :(
As per my post I'm doing a few cosmetic things now, like I've had a set of side skirts since november last year that were meant to be put on before I went to the UK in december that still arnt on yet :( Plus paul has some rims for me, then I think a catch can after seeing the oil in the intake manifold today and a ogura flywheel as well :)
Originally posted by gtrken
Bye Niz.
Cheers
alszcheimers
Ken
Yeah i know - they werent even appreciated so it'll be the last time i do that haha
I'll ride with anyone who wants to give me a lift - beats walking anyway haha
**gone for good now** Later peeps!
paul - sweet... zanda will probably be wanting to come too... i supose we can't have too many people otherwise accomodation will be hard to find...
as for drinking - i'm sure i'd be up for that.. would like any chance to drink u all under the table.. :(
aidwin - cooler is on the cards.. some guy got 275rwhp with the same setup as me, well close to it, cept he had a front mount.. so for an extra 25hp it could well be worth it.. me don't want to sacrifice low down power tho....
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
