  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
oh yeah i have a conscience - no brain just a conscience haha. I just dont feel that im going to go to hell cos i slept with someone out of wedlock - or swore and cursed or i didnt bible bash other people.
yeah im going to the pub for afterwork drinks with my mate tonight - im driving tho :P
I went thru a booze bus last night - thursday night at 7pm on Roe Hwy - i only go thru them on weeknights! Havent been thru one yet at a time i would be drinking!
getting a bit better...
had a call from work - they had a meeting and said "hey, cam's just been to asia right? And he's got the flu right?" - next thing i get a call saying make sure you're well before you come back.. I said thanks for caring man.. he said - no i don't think u understand.. make sure ur WELL...
i said the dreaded sars word (i did get checked for it by the way) and he said that a few people at work had seen me sick and were quite scared.. funny huh?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
