  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
    • hello ladies and gentlemen so i’ve swapped a rb26dett into my r33 gtst and ive come across many speed bumps but its nearly over what im having issues with is the injector resistor box that are normally on the RB26 fuse box but im still using my rb25 fuse box and as a result my injectors aren’t getting power and is the last thing i need to figure out so the car can start. can anyone help me out on where i can find a wiring diagram for the rb26 harness to see where the injectors are supposed to receive power
    • The boost pressure at the compressor cover will be higher than at inlet manifold. lets say, trying to hold 20 psi flat at 7000 RPM. If your wastegate opens at 20 psi measured at the compressor cover, the engine may only be seeing 16 psi. Your base pressure reading at engine would be 20psi by 4K and 16psi by 7K while your MAP at compressor housing still reads 20psi at 7K. For this reason your ECU's MAP source is never on the compressor cover. This difference isn't a major concern if you're using an electronic boost controller (EBC).
    • Zoomed in they look like oil paintings
    • Some of the photos from the aurora taken on my s24u. Night mode doing the heavy lifting.
