  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Troy, too much info:spew: I thought she was angry at you on Sunday at the race track?
Men are dumb, can't see why women like us:D
See'ya:burnout:
Because when we get around our girl friends, your dumb but sincere comments are always good to laugh at!!!:uh-huh:
