  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
which is why I can't work out why people try to make their GTST's into R copies or try to make them faster.
My saying is that if you want a faster car , buy one from the manufacturer. Usually works out cheaper in the long run.
Cheers
Ken
Originally posted by caminperth
ken - yea.. well maybe half of it is in my head - but i honestly think it has made a diff.... u don't think they are worth it?
I assume you are talking about the brace between the shock mounts under the bonnet and not the sway bars under the car.
Strut braces work if they are attached to the suspension ( ie Macpherson strut style. )
The lines are double wishbone and the mount you are attaching to is not a stressed member of the car.Also unless it is straight and substantially thick , it will flex anyway.
I think you would find if you did an MC type day with the bar on and off , the difference would be marginal.
But hey , it looks cool and I have em on my car ( cos they came with it )
Cheers
Ken
Cheers
Ken
ken - hmmm everything you say sounds right.. but it still seemed to make a difference... maybe it is all in my head... but as you said - they look cool.. hehehe :(
paul - springs will be on the cards definitely.. was talking to no_respect tonight when i picked up the brace - his is about the right height (only about an inch lower than mine) and he said that he still retained a firm but comfy ride... he also said they're pretty damn easy to fit?
Originally posted by rob77
Ken, any pics or details of mods at all?
Ahh let me think
ARC aircleaner box
Big gay ally wing
18x9 BBS
Momo wheel
Recaro drivers seat
1/2 cage ( not in atm )
cusco shocks all round
Nismo top and bottom rear arms
Nismo caster arms
HKS evc4
4 defi gauges
cusco 1.5 way super f**cking loud diff
ogura twin or triple super f**ing bitey clutch
Got some pics of the as arrived condition but need your email addy.
Cheers
Ken
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
