  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i tried fitting my bov yesterday but the flange is at an angle where i cna't close my bonnet cos the bov sticks out too much! :)
i have to find sumwhere where i can get them to cut the flange off and re weld it back on at a diffrent angle so i can fit the ****er!
adrian :(
Morning all,
So im listening to a commercial radio station this morning (dont ask me y) and i hear an add for stickers or something like that.
"wether u have a HSV, nissan skyline or a corrlla u should come to us"
So have skylines beocem that popular? or do they just get alot of stickers made for em? id hate to think that the line was a poplular as the hsv (even though u see more of em on the roads nowadays)
Ahh well just thought id share :(
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
