Ooohh looky what i found. This is something i have never seen at the motoplex http://files.franzonline.net/images/ it has some nudity in it so no direct links but tis the holly shoot to set u on the right track.
Oh yeh none of these pics are worksafe so open with care.
Does any1 know the 33 there?
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i had this bitch in a Honda (Y is it every dickhead drives a honda) sitting in the right hand lane next to a truck today blocking it so nobody could get past. After sitting up her arse for 10mins i decided the truck was probably going faster. So i got behind the truck and the two lanes were merging into one - so i decided to be a bitch back - she was going to try and get in front of me behind the truck but i blocked her. So then she finally decided to try and overtake the truck but the truck decided to merge lanes early and came very close to crushing her car - she jammed on her brakes let the truck go past - by this stage i hung back a bit - cos i did my job gave her the fright of her life - anyway she got up the trucks arse - truck jammed on its brakes and she nearly went up it. I was pissing myself laughing the little bitch got totally what she deserved - im not normally that mean but dickheads who havent got a fricking clue about road rules and dont show common courtesy to cars dont deserve any kinda courtesy back!!
:P GRRRRRR
    • Thank you for the feedback bro. Looks like it’ll have to stay off the road till it gets an ecu
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
