  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
no i know ken - but they seem to have outdone themselves in poorness this time - its likethey got worse not better!!
Get back to moir on what aidwin?
pwptpf , mack daddy , aidwin. boy aren't we the busy one?:P:)
Cheers
Ken
I won't let the wife take it to soccer training if there is more than 4, mind you some of my eldest's are bigger and uglier than me, and he is only 12. Kal is great zero degree's in the morning and I feel fine. Biggest problem is letting the rb26 warm up before I give it some stick, it warms up when I get to work!! But I have been known to call a missed approach and go around. All you turbo car guys and girls should make a trek up here July / August, cold air is like adding Nox
Originally posted by SHUTO-BOY
dvd's Niz
mMm SAU dinner
yea that sounds better. That way we can drink , throw stuff at the TV , get up for another beer or to puke...
just don't get one of those DVD's where the shadow of someone in the front row getting up blocks the pic.:P
Cheers
Ken
for me at the moment its just mmmmmm dinner - we have f-all in fridge - mums gone away for a week - dad will join her fri night - i have no money to top up the fridge - so im a starvin marvin at the moment!!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
