  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
got more than one friend named ryan - ken :D in fact my phonebook is like noahs ark - theres 2 of every name haha :P
Haha , you crack me up sometimes kid.
oops , can't say that now with you being 20 and all.
It's a downward spiral from now on.:)
Cheers
Ken
im still a kid Ken - it pays to have contacts :P Speaking of which i need someone that can install rear speakers! I know someone that can do it - but hes a good friend of my ex's - cam and i are still real good mates but because of the situation i would rather not use him if i can get away with it.
Originally posted by gtrken
yep but the wildlife will worry a lot of us heading up that way.
Did you see the post re. the starter motor ?
Cheers
Ken
Sure did, thanks for you advice previously as to how to extract the noisy item, I have a friend who is the original self taught wizard of all things mechanical and performance and we will have a crack at it next weekend, as for the wildlfe I haven't seen one yet but you can't afford to blink if your going a tad over the speed limit. In all seriousness most of the offending Fauna will have absconded back to the bush following the rain we have had. You would run a greater risk of doing points than doing damage.
Yea Tim , could be something to plan for later in the year.
Some of us are doing an o/night at Albany the coming long w/end so will see how it goes.
Is there any budget style accomodation up there we can stay and is there any ..err.. free expression bitumen areas to ...err .. have some fun on ?
Cheers
Ken
ive seen the pics russ - geez i thought i was putting on weight!! But she makes me look hella slim - shes even fatter than the duchess of pork!!
Can't see what people see in her or Britney. I think there both skanks and wouldn't touch them even if they begged.
yea riiiiiight !!:P
Cheers
Ken
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
