  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
got more than one friend named ryan - ken :D in fact my phonebook is like noahs ark - theres 2 of every name haha :P
Haha , you crack me up sometimes kid.
oops , can't say that now with you being 20 and all.
It's a downward spiral from now on.:)
Cheers
Ken
im still a kid Ken - it pays to have contacts :P Speaking of which i need someone that can install rear speakers! I know someone that can do it - but hes a good friend of my ex's - cam and i are still real good mates but because of the situation i would rather not use him if i can get away with it.
Originally posted by gtrken
yep but the wildlife will worry a lot of us heading up that way.
Did you see the post re. the starter motor ?
Cheers
Ken
Sure did, thanks for you advice previously as to how to extract the noisy item, I have a friend who is the original self taught wizard of all things mechanical and performance and we will have a crack at it next weekend, as for the wildlfe I haven't seen one yet but you can't afford to blink if your going a tad over the speed limit. In all seriousness most of the offending Fauna will have absconded back to the bush following the rain we have had. You would run a greater risk of doing points than doing damage.
Yea Tim , could be something to plan for later in the year.
Some of us are doing an o/night at Albany the coming long w/end so will see how it goes.
Is there any budget style accomodation up there we can stay and is there any ..err.. free expression bitumen areas to ...err .. have some fun on ?
Cheers
Ken
ive seen the pics russ - geez i thought i was putting on weight!! But she makes me look hella slim - shes even fatter than the duchess of pork!!
Can't see what people see in her or Britney. I think there both skanks and wouldn't touch them even if they begged.
yea riiiiiight !!:P
Cheers
Ken
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
