  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah I have heard you guys are getting a bucket load or rain and wind over there????
Is it possible that Melbourne has actually got better weather than Perth!!!! :(
We have had a bit of rain today but it sounds like its nothing compared to what you guys have been getting.
yeha its horrible - except when its at night like this - all i need is a log fire, nice red, no work tommorrow and someone to snuggle up to and life would be grand - since i have none of those things i might as well be content wrapped in my doona talking to u - although im not gonig to stay long - nearly my bed time :(
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
