See ya Joe
I will talk to steve again next week about it. I checked the NGK website earlier & it said the same thing about a car with an ecu needing the resistor type (4ohm btw macka).
Said something about issues with idle, etc, etc.
Funnily enough there seems to be a miss at idle, but I took the car out for a lap between showers & it does seem to go better with the new plugs.
Also noticed that the rev limiter on the mines ecu is set somewhere between 8500-8800rpm. Strange thing is I never noticed that before cos I was sure that it was cutting in at 8200 as per the stock ecu that I had:confused:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
That should be bloody good fun Ken.
What time is it cos I got nothing on in the morning so I might come out & watch.
Behave yourself Clinton...you are not really in a position to throw stones
All day starting at 9am at the racetrack.
Instruction sess in the morning and hot laps after lunch.
I won't be taking any R's up cos one is at CRed and the other is going for pre sale inspection Tuesday.
Cheers
Ken
Should be interesting if it rains next weekend ken.
Would you still run the day if it is wet?
Shit yea, best time to run em.
Plenty sideways action with no tyre wear.
Cheers
ken
Originally posted by Pva_Glue
my mate just changed his spark plug on his soarer TT...
100.46 for irridium spark plug....$$$$$ char ching!
Why ?? Iridiums last about 50K KM while NGK std plugs ( bout $2.50 ea ) last bout 15K KM.
Cheers
Ken
    • Thank you for the feedback bro. Looks like it’ll have to stay off the road till it gets an ecu
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
