  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
ok with 5 secs looking at that dont buy resistive plugs
If you have a problem u can rectify it later as long as you find  A good Electronic Teck :P
Resistive plugs may cause u to have poor ignition bud  fact
Must be why Steve said not to go for them.
having said that, it seems to be against the norm but I trust his experience.
Plus for the $17.50 they cost, who cares if I need to change them for the others.
BTW - he put me onto 6's, not 7's as most other people use...
But you need resistance plugs if the car is electronic computer managed according to the tech article.
Or have I missed something ?
Cheers
Ken
Yeah go the colder plugs
Not so easy to start in the cold just pretend ur startin a carbed XD
hehe
But it helps stop pinging :P
errr 6 is hotter than 7 . NGK goes the other way to most heat range spark plugs.
Cheers
Ken
Cheers
Ken
You're right ken - i might go get a set of resistor ones before i put the car back on the dyno - then i can compare them to see if there is a difference whilst the car is on the rollers:uh-huh:
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
