  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Hi Micko, Danny, Jason and Troy.
Danny, you can do what ever you like in this thread. What's happended with the Schlack box?
Err , that's Challack box , Shalak is close to a clear paint. hehehe
Cheers
Ken
ps , check the thread you posted in re. forks pwptpf.:P
Steve was saying there are only 3 manufacturers in Oz, and there all about the same price.
three manufactures in OZ who are close and one who is bend over expensive ( Hollinger )
Cheers
Ken
Jason, We'll have to come up with plans for you new shed:D
Hi Ken, How are the WRX's coming along, whats the next major event?
Still stripping proof coat off the floor, what a ****ing job.
Am going to Speedworks then CRed tomorrow so get a day off to let my muscles heal.
Cheers
Ken
Originally posted by GTS500
race torque $7500 box, $1300 forks,$300-500 fitting lots of cash and all the ones i've seen have blown
Yea , with the forks and build I suppose that's close.
Could try waving some cash at Kim Ledger.
Cheers
Ken
    • Talk to hot girls via live cam. Adult dating made easy and exciting. https://secrelocal.com private ladies for discreet encounters
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
