  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
just saying hi!!
I got the bushes done at wilkinsons.... I didn;t stay and chat to them about the car I was sick as anything. I feel really rude for it. I went to the docs today... all from the friggen car accident! I didn't even know I couldn't move my neck properly! lotsa headaches - should all be gone soon!!!
Originally posted by Sneeza
just saying hi!!
I got the bushes done at wilkinsons.... I didn;t stay and chat to them about the car I was sick as anything. I feel really rude for it. I went to the docs today... all from the friggen car accident! I didn't even know I couldn't bend my head down all the way! lotsa headaches no sleep - should all be gone soon!!!
What , your head or just the aches. rofl.
Gees I crack me up somtimes. hehehe.
Cheers
Ken
PS did he do you a good deal on the bushes ?
