  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh they drive a cetain way, all cops do, its more a vibe than anything concrete.
I saw a magna run down a traffic light this morn too man that was funny. U look at the angle and u cant figure how the hell he got there, the traffic light was stuffed too.
ive had a close encounter with a traffic light before - caused by me locking my brakes up and my Zx backend slipping out and redirecting me in the way of the traffic pole - close call think i left quite a bit of rubber on the road stupid newbie driver i was!
Anyway hometime - see all that are going to SSt's tonight. :P
