subway is good though bambam better then maccas!
yeah troy i always wanted a r2d2 u just want me to get it coz it related to star wars GEEK! :P
hmmmmmmz maybe i just chuck the stocker valve back on
nah paul mine only stalls when the revs drop suddenly :)
adrian:p
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Adrian_perth
24 hr subway?
i'm up for some of that for sure
adrian :P
wanna bring me some i'll pay u back
chicken teriakie with cheese and bacon with lettuce and onion
bbq sauce white bread. actually i can pay u back now found some cash in the work bag :)
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
