  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Alex sounds like uve been in the situation before and things went a little wrong.
yes i did the whole - ruin the 5 year friendship thing - but we still talk a bit :) its not all bad .... i tried to shove him outta my life and he keeps coming back so ive given up haha
so?
women are the most fickle creatures on the planet. they're worse than praying mantis'.
either way, she'll end up not talking to you at some stage. I have had many good and close friendships with wimin, but rest assured that there will eventually be some over-heated over-inflated faffy friggin drama that gets blown out of proportion and then the "super-tight bond we share" turns into death glares across a crowded nightclub.
better to "sink and sink" than die wondering how deep the water ran.
Paul: I formally deny those accusations..... ( Yeah that should cover my tracks )
Troy: Ironically this isn't far from the truth but alas I obviously meant to state there was 1 relationship of 4 years....
Yeah where is Bayley... I got promised her 18 pretty blonde friend last time we were all chatting about it :)
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
