  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Bummer Ken, do you think the ricer will cope? Non-synthetic is mineral isn't it?
yea pretty much.
Use a cheap mineral oil with not too many friction modifiers in it and change at about 1000Km
The ricer should be ok but beats watching from the sidelines.
Won't win but hopefully will pick up some points.
Cheers
Ken
Ken, If I join WASCC, on the track days am I allowed to take a passenger?
Umm , not sure , don't think so unless a recognised WASCC instructor ( of which I'm not ).
Cheers
Ken
Sorry guys - I'm back...
yep Ken - looks like I'm going 2530's - I know that other things will need to be upgraded - I assume you're using the bigger injectors you had on your project?
I know of other people getting away with standard ecu, etc with these turbos (i.e. Brett Hackett) but I will try to push for everything whilst I can get it:D
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
