chance it'll be extended Erin?
Mine is to the 30/6 but there are talks maybe til Oct sometime now - my boss still told me not to get to comfy so im taking his advice!!
Talking about not gettting to comfy its my hometime :D
Later all
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey rob
hks controllers are a heap of bog
maybe the new ones are better.
I dont think it would matter on the needle valve too much if i laid the solenoid on an angle shaggy.
Also i dont have a duty cycle what i was talking about seems to be an "offset" to sync your reading from your ebc to your boost gauge as they are always going to be different
Spot on mate... I've been doin a bit of reading up on it aswell..
After it was playin up the other night, i pulled apart the solenoid and found a little bit of rubber stuck in the valve, cleaned it out and it runs sh*t hot now.I ended up mounting mine almost sideways in a cooler part of the engine bay.
i dunno guys.. It holds boost nicely, then suddenly drops and almost holds a lower setting.. It's too sudden and neat to be the actuator spring. Rob might be a silly question, but you've unplugged all the factory boost solenoids and crap haven't ya.. try a bleed valve and see what happens.. i would have thought the spring would drop off boost slowly as it struggles to hold it, not just drop it from 13 to 11psi instantly.
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
