  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Angel !!!!!!
Babe , where ya been ???
We missed you and it's hard for only Lauren , Liz and Bailey to fend off all thes guys. They need help and now your back.
Hehehe:D
cheers
Ken
ps , oops , I forgot Kyles.
Hi Ken and Troy. Work? Don't ask. Still looking for real 8:30 - 5:00 type job. Have taken 8 weeks off part time to study. They asked me at work if I minded doing a few extra shifts on the days I am not studying. Now I am working 41 hours a week and studying 3 full days a week. And I am renovating my house.
Hardly time to wax my baby.
I WON in the car park war! You would be so proud of me troy boy. The bastard didnt even get a word in hehehe.
Kylie : "You where so rude to me calling me on the weekend. Troys car is worth more than all your cars combined." the idiot tryed to get a word in but then i said loundly "and.. you should have though before you bought 3 more cars you should have though about where you where going to put them. Im not moving house, I was here first. So you just have to find else where for your cars beucase your not getting my car space in the car port"
sucked in.. dont mess with kyles .. hehe i was cracking up laughing . Hes awnser was after a few seconds of silence. Ok. So i said thankyou and hung up hehehe..
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
