  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
yes I have standard rims....
I;m in f*ucking tears - why do people have to be such c*unts.... that word is bad - but I don't care. I have rung up like 50million places trying to find discs... I get laughed at, talked to rudely. Cars are f*ucked. Its my own stupid fault for being so trusting
I didn't want to ring you ken cause I didn't want to be annoying... I;ve bothered you enough
Liz , don't cry or it will set us all off * sniff , sniff *.
There is no problem , you have given him no money and he supplied the wrong goods. leave them there.
I will find out Tuesday what is around but be prepared to buy some new ones. Is prolly the best thing anyway cos 2 nd hand ones can be a bit dodgy ( cracks or undersize )
Cheers
Ken
Originally posted by zanda
Yeah, Liz.
other option is to try and find some bigger calipers. these often seem to appear on the f/s lists.
Ken, can't the caliper mounts be modified / fabbed up for not too much $$$?
But why bother. You can get new discs for about 280-300 ea. Will cost that much just for the adaptors and machining.
Cheers
Ken
Liz unfortunately it goes with being female and having a fast car - ive had it done to me as well ;) peoples attitudes wont change - but the good thing that comes outta all my car hassles is that next time i know better :(
Why can't ppl just be honest and nice?? I ask stupid questions on here and I get the piss taken out of me.... I ring up places to get a product and I get laughed at or hung up on... what the f*uck is wrong with people.
Liz , don't get so down. You sound like Mr doom and Gloom Belgarion on the QLD whores.
It is not a big issue. Would be worse if you paid for them first.
Cheers
Ken
mmm chilli con carne - gotta have a big dob of sour cream on it :(
I got chicken on the sink defrosting - not yet sure what im going to do with it but im the only one eating it so it dont matter - hmmm i might see if theres some filo pastry in the freezer and do chicken,bacon n cheese filled parcels - hmmm yummy ;)
Dancing might get ur mind off things Liz ;)
Ken - then I am as bad as the people who are rude?? I can't be mean to ppl... I need to toughen up... someone be mean to me .... quick
I feel like such an idiot. People are going to read through this and laugh
Bullshit.
You asked him would they fit and he said yes. If you said you would just take them then I would say that they are yours.
Not your fault he lied to you.
Cheers
ken
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
