  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
did anyone watch the show - The Block - last night?
and that stupid bitch on it tha wouldnt clean the toilet so her hubby did it? hehe where do i find a guy like that??? i throw a tanty and instead of being told to "grow up and get on with it bitch" he just sighs and fixes the problem??
I think Im a bit too much like that.
I dont know if its a sign of weakness or a rationalisation thing. You think - is it easier to go through the consequence of telling her to grow up and do it herself, or to just clean it myself?
the problem is, that he will eventually leave her because that becomes easier than putting up with her.
Now I try to be as honest as I can with my girl. sometimes I have trouble explaining why, cause I don't like hurting her feelings, but Im not afraid to tell her to go g-f occassionally.
haha.
shit yeah that would be sweet!! maybe have to wait til its at the drive-ins at Busselton later on and make a cruise down there - stay at my place in bunbury? if people can bare seeing it for a second time haha
that "the block" show was pretty funny.
the gay guys are gonna clean up. they've got style and two men on their side. Plus Jamie Jurie will give them a "hand-up" (if ya know....) coz he's a fruity-tooter too.
Funny watching Joe and Mo whitebread slinky sinky BMW house stereotypes go scatty after 5 seconds.
"im not going to the toilet in there....I'd rather piss myself"
"well then bitch, clean it up"
"Im not cleaning it up, Id rather you did"
"o-kay"
thats what my ex said he liked about me - he would tell most girls to go do something and they would sigh and go do it - he would tell me to go do something and occasionally i would but there was quite a few times i told him to get Fked! He liked a challenge ;)
As for worst drivers - that italian looking chick man is she bad - but i guess she brings in the male views cos she always has tops on where theres a LOT of cleverage on show!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
