  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by 33Spec2
adrian i swear i saw you in varga but i wasnt sure coz after a few drinks every1 looks the same:p
What are you saying russ? that all black guys look the same to you?
'specially if theyre sailors and you've had a few, do doubt!!
*husky voice*
mwwroooaor! you look mighty fine in that pinafore outfit big boi!
:P
alex, i ordered a cooler kit for myself, just too make sure that when you guys are ready to order you won't get caught by customs! coz i didn't want everyone to end up paying tax, so i thought if anyonewas gonna get caught and pay customs tax it would have to be me :P i'll let ya know how it goes, it should arrrive anytime this week :P your welcome to come check it out, as cam and paul gonna give me a hand fitting it i think :D
adrian :P
