  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by angel
Ken if you can't control your breathing don't blame me. If the wife notices, just tell her you have just done a major cardio workout.
Creative accounting whilst intoxicated...
I always heavy breath...
Creative accounting got Alan Bond 2 years:D
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken, I'm not the only one who should be going:p You'll improve your hill climbs with less baggage:p
Tried to give myself a handicap to give the rexes a chance but alas...
they will just have to go faster. hehehe
cheers
ken
Well goodnight everyone. Sweet dreams, keep them clean, and if you can't ensure they involve at least 5 different positions, one form of spread, a swing and a great deal of stamina.
Hmmm well I hope to see YOU in my dreams then
Niite Angel ( or not so by the sounds of it )
hehehe
Cheers
Ken
Haha, I spoke to Steve, he blamed the drivers on the loss:D He said you'd be over 1second quicker in there car:D
Quicker than them or quicker than my time ?
cheers
Ken
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
