Originally posted by GTS-t VSPEC
Ken, It worked out well for both of us then:p
I can't believe your Mrs talked Danny's Mrs into allowing him to do more motorsport, how ironic:p
Yep , that worked. She's on sales commission if it goes through.
Damn , more brownie points I owe..
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by caminperth
you guys are going to love this one - saw a white supra today.. with the blue ford cobra stripes down the middle - it even had the cobra decal on the side of it!! :D hehehehe...
Don't try and chop it , that is one serious mofo car !
cheers
Ken
zanda, i remeber trying to do buiness with this very same character a year ago. I rang him 2wks after he claimed to have sent a fuel controller via COD and the lazy fscker hadn't even uninstalled it from his "friends" car yet. I didn't lose any money but i was waiting around for something that was never going to show. Let him burn I say.
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
