  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Wont be fitted for a while paul. I got it from works auto who was selling it for one of their customers, who they dont have a phone number for. No-one could really tell me the full story behind the turbo, simon could only tell me the guy who had it last got it off a rx7 and was going to put it on his rb20det but decided it to be too big and laggy for it. Apparently its been rebuilt recently, the only things worrying me is if its naffed (ie: needs another rebuild) and the A/R so I can find out if its going to be a lag monster. From what simon says he reckons 3500-3800 full spool up. Its going to grant on sunday/monday for him to look at and tell me what he can and also how much to fit it to the std manifold+oil lines+ext wastegate. I might get it put on sooner depending on all up costs. It was far too good a price to let it go and considering a mate of mine with a r32 wants my std turbo the change-over cost is amazing.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
