  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by 33Spec2
you two shoulda been picking on the guys not the girls!:O
i saw the son of rajab of the rings episode yesterday! hahaha so funny
This chick was farked. she did about 7 laps at scarbs and she was driving like a complete knob... she deserved what she got. Niz gave her the finger then kicked her arse hahaha I just sat behind her with my horn blaring hahaha
*enter the honda killery* :wavey:
haha she was a god damn stupid bitch - man Liz u shouldve kept up cos i killed her - i made her look sooo bad it was not funny - stupid cow!! I couldve dragged her in an excel and won.
The ex things head phucked me quite a bit tho! i didnt realise how much til i got home and i keep dwelling on it even tho im trying not too. i really hoped he had his life together.
