  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
ken its not - i want to go back its more he's destroying himself and now i feel partly to blame that he's gone so downhill! Ive been living in this "he's ok, hes doing fine - someone suceeded wher ei failed bubble" and its just been popped and i feel head phucked.
Why, and have him pull you down to his level as well.
Niz , if you left him there must have been a reason for it so I am sure the reason is still there.
Cheers
Ken
Unfortunately i cant help but blame myself. But he's bought it all upon himself - just hard to see someone that u used to love and part of the reason i left is in the hope they would find help but now he's worse. Bu thats the first time that since we've been apart and ive bumped into him and he's just uped and left - usually he's really pleasant and friendly today he looked like death warmed up.
garlic prawns yum my favourite ..... havent had dinner. Cant be stuffed.
Im not normally one to let people upset me but i think i just care what happens to some people too much - i honestly dont want to see him unhappy ...... i would love to walk away and not care but at the end of the day i do.
haha honestly ..... what did u think Liz? not that u got to see much of him and he didnt smile one bit the whole time - which is a pity he has a really nice smile.
Thanks Bam ya softie :goruphug:
hey cam who was the chick u were with - u seem to have a different one for each week :D
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
