  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
A manual gearbox , then a Power FC.
Just kidding babe , just kidding
* oww , stop hitting me niz , oww , oww*
:D
Cheers
Ken
Niz takes brownie point off ken :bahaha:
so einstein ..... keeping the auto transmission what is the auto subsitute?
Originally posted by BelGarion
i was refering to my post speed and my cars speed ken.....
but so be it anyway
err yes , I understand that Bel.
It was all the ones previous I was refering to.
Don't get me wrong , it's not like I don't care , it's just what can we do about it sitting in front of a puter reading you posts that hasn't been said before.
Cheers
Ken
Liz i thought she was going to take ur front end off!! Her grudge was obviously with me cos it was me she was cutting in front of u to chase - all hond adrivers are the same - they have small man/women syndrome and they only make it wosre trying to take on proper performance vehicles oh well they make me look good os i shant complain!
Haha ur dad sounds crazy - my folks are crazy when their drunk but their a little closer to home than germany unfortunately!!
well my mechanic is the motech man sooo if i ever have a lot of spare cash lying around it may be an option. Wasnt sure whether the wolf would do autos or not but that ansewers that question - thanks :D
Liz next time u see him tattoo it on his forhead! no but its unforgivable ur dad not knowing ur birthday!! ...... then again i know the dates of my folks birthday but i forget that on the day its their birthday.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
