  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
alex, is that the one form dabigbolf? if it is be weary, most of them a Prof sheepdogwannabes, they all copies :) the original prof sheepdog bov doesn't have a trumpet and is meant to be plumback, i should know coz i use to have one before i got my blitz bov :) and the original had prof written on it :)
adrian :P
nah, Niz, Im still here.
I had a REAL ugly relationship with a girl who was a little bit unstable a few years ago.
It was really hard, but in the end I walked away from her, in-spite of the fact that I really loved her. it was one of the toughest things Ive ever done.
I havent spoken to her for years, but I try to keep an ear out to what she's up to.........I suspect she probably hates my guts.
troy - haha its a very involveded story and there a LOT more to it than just your average break-up but for my ex's sake its not a story that should be broadcasted over the internet. Lets just say hes someone that i should be worried about & if anything happened to him i wouldnt forgive myself - guess even tho we've broken up i still phucking blaming myself for his every downfall.
yeah Alex - i know its hard to walk away from someone u love. Took him about half an hour to spy me yesterday and its the first time he took one look at me and walked out - we'd always been really friendly up to then he even gave me my nismo strut braces when we had broken up ........ but now i think he blames me too.
Niz - I dont know the story, but generally speaking, if someone "becomes" unstable, it's much less to do with their interaction with others and more to do with pre-exisitng issues which surface as a result of stress/fear/loss etc.
So, a bad relationship can be a trigger, but the problem is usually pre-existing.
yeah its hard when u have to lie to everyone - even my folks were asking this morning how he was and i had to lie thru my teeth - i thought when we had broken up i could stop caring and stop lieing - still phucking doing both. Anyway sounds like im talking in tongues if u dont know the whole story - sorry - just need to get it off my chest. Im trying to think happy thoughts :P like m & m's but im too lazy to go up the shop and get some
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
