  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
maybe alittle higher
i added 3-5degrees of timing into points on the timing map to fix the hole in it.
others just ran more boost.
the dyno had its software updated during the week so that may have recalibrated it. was good though had about 32-34 cars run on the day
Originally posted by tenzero
Anyone out there know of some good tricks for pulling rice boy stickers off of the doors without taking the paint along with it??
My new baby needs a little de-ricing.
Hairdryer to soften the glue and some T Cut to get the dark paint mark off thats left behind.
Cheers
Ken
