See ya Kyles:)
Yep - we are sure that it never did it before Ken.
It started last night - we went from your house to the servo near me, he filled up & then it started playing up. Is there any chance that it could be associated with the pcv as aside from the immobilser, that is the only thing that was altered on the car recently?
Could be because the wing isn't on it any more:bahaha:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
See ya Kyles:)
Nah , car is back to the same as when I ran it. ie. pcv blocked , breather cleaner on.
Only change is the immobiliser. Are you sure all the wiring has been put back to std when you pulled the immobiliser
cheers
ken
Originally posted by GTS-t VSPEC
Damn, That was a pathetic Saturday night of whoring, took me 2mins to read back:p
Hope the cruise went ok:D
Ahh yes but some off us have a life and DO actually go out .
Think a lot might have cruised with epoch and I did the brownie point thing and went to La Cascade in Nedlands with the missus.
* Thinks , would rather be out cruising*:)
Seeya Paully and get off this damn puter and go on holiday:D
Cheers
Ken
hehe hey Ken .... me n Liz got into mischeif last night :D
We stumbled upon the South Australian Football Club and the club president was trying to pimp his guys out to me ....."What about this guy? hmmm do u like italians? ........ can i introduce u too? ..... Cmon just tell me which one you like and i'll see what i can do"
Had such a funny night ..... i think me n Liz really needed a night liek that :uh-huh: certainly got our minds off things! :)
anyway must go pick up mel for lunch in freo .... Liz maybe i should go bang on room 1033 and see if they are up yet haha i would imaginethere would be a lot of hangovers this morning!!
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
