  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
4 hours?? ack!
Mel n I went and had lunch at Little Creatures Brewery - bottle of wine later - we decided to go see a movie ..... but Bruce Almighty didnt start for an hour ...... so we proceeded to the pub for more drinking :)
Yes thanks niz.. I CAN EAT YAY!!!! Now that im eating, antibiotics are working feeling much better. Still a bit sore but i will be for the next few weeks.
Sore throat niz? Try some diffram, Lozingers that have anti inflamitorys and anterseptic. They taste ok, but suck them right at the back of your mouth or your toung goes numb and when you talk you sound retared... lol.. ive done that lots whopsy!
haha Kyles sounds like the stuff the dentist numbs your mouth with :) i always talk retarded after the dentist - puts me in a bad mood! - glad ur feeling better :)
Bam .... i drink about as much as any person my age :(
watched the movie - all the best bits were in the clip tho :) so the movie was pretty lame after that.
i spilt beer on myself accidently before we went so threw out the movie i smelt like an alcho - i kep ttapping mel on the shoulder "hey mel - i smell like beer" 10 mins later "god damn i smell like beer" haha she didnt mind she was more pissed than me :)
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
