  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sorry Niz... nah I am still hyped from the stress at work hahaha and i went to the gym to calm down... didn't work.
My boss is working on it with me... so not my fault hahahaha We happened to hit a bug..... just as we were ready to release... its just that this bug kinda screwed everything
Liz sounds like u need a drink! not been a good week for u - next week start afreash and try again? Which gym do u go to?
Rob - haha oh well its what my cars got now - cleaning the mags is good therapy anyway :D
haha thanks rob .... i think. U got a ricey kit picked out for ur car yet? my back wing is currently being held together by packaging tape!
Liz thats good - exercise for some reason helps u run off some of that adreline :D
Nah... I'm not a fan of kits. I'm leaving the rear wing as is, probably just change the front spoiler for something basic... I've been trying to get a m-spec front bar so I can modify it and get a plastic welder to fix it up for me, so it would be unique. Apart from that the only other ricey thing I would put on would be a carbon fibre bonnet, but thats a long way off... my main concern in HP :D
haha the good old vodka in the water bottle and bourbon in the coke bottle eh Liz? yeah i miss my lunches andrew used tot ake me to on his day off ..... we would sit donw the pub for an hour and knock off whatever we could ...... used to go to work so much happier afterwards :D
Does your boss understand the situation?
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
