  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe Bam - least it sounds like an interesting life - give the king a big sloppy kiss from me :) & for god sakes tell them that Jeff Gallop is the premier Not the prime minister!!
haha James - never say never ..... how about if u find a girl u love and never want to let go ...... marriage is like handcuffing her to u :rolleyes:
i think its funny cos those that say it wont happen its usually the first to happen too.
thats why i never say anything about stuff like that ..... ive already made myself look like a hyprocrite one big time in my life.
hope noones car was injured :)
when i was 16 i took the piss out of this 18yr old girl i worked with who was dating a 28yr old and living with him and doing his washing etc - i even remember telling my mum that the age gap was huge and i dont know how she could do it etc ............ guess what i was dating when i turned 18 ....... i had to eat my words totally! :rolleyes: and since then ive kept my mouth shut because i think i cursed myself.
haha we had a Mazda dealership next door to the car dealership me and my ex worked at anyway him and his friends went and stole one of their M-Day Sales posters put it up in his lounge room on his side so it looked like E-Day :rolleyes:
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
