thing is with a retainer plate u used to slur your words sometimes and the kids used to take the piss out of me for it ..... patricularly one guy - funny thing is i "grew" up and all of a sudden he stopped his teasing and started with the flirting ..... lets just say he didnt get very far!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah it was pretty funny actually cos i used to get teased for being lanky and tall all the way up til i was 13 & then the most popular girls at school were the ones with the biggest boobs .... haha which definately wasnt me .... then by 15 i filled out a bit and started wearing skirts and had the most popular guys chasing me which made me very unpopular with most of the girls. oh well i deserved that after 13 years of torment!
dont know - one they are doing up in Morley apparently going to be real hoity toity!! Joining up with Mel, Chantelle & Tammy < they already joined i join on monday and go with mel for a "examination"
:cuddle:
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
    • Looks better than dusted paint, and also looks better than the old OEM one, much happy
