  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha i was conned into it Paul! ..... besides i cant join with u - for some of us a gym is an unglamous thing :) these girls will drag me along and make sure i go - plus we can gossip on the treadmills :)
Bye Bye Phil
sorry if im slow - trying to edit document and whore at same time
yep - gets her away from her bitch of a mother.
we are going shopping on Saturday. she's got her company ball that night and is coming around to check out my ball dresses (from the days i used to get invited to stuff like that!) and then we are going to pick up tickets for a party we are going too and buy gym clothes.
take me two buses and about just over an hour to get ot work - besides when i see people standing in the wind n rain at a bus stop i think 'suckers'
my have to start catching lifts into midland with my parents when they go to work - catch train from there .... just dont want to be a burden on them - but this cant go on - its chewing up a big portion of funds!!
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
