  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha sorry been at a 2 *glances at clock* make that 3 hour lunch break .... wine making my face red *giggles* why cant every work day be like this - im going to a country where they have siesta!
well this guy thats leaving - i want his cubicle - its got river views and a bit more sheltered. Im doing part of his job anyway and since the lady thats did the job im in now is coming back off maternity leave - i want to do more of this guys thats leaving job and go work for his boss - and the lady coming back can do this shit!
least your mum knows what boost is
My mum goes "Lauren u really need to have the whirring sound looked at by a mechanic"
Dont worry my mum lectures me about "im going to lose my license cos i drive like an idiot and im gonig to kill someone" drives me insane.
my mum drives a holden clubby yet the power in my 300ZX scares here shitless ...... no more needs to be said haha
wassup for the weekend James?
Me n Liz are going drinkies Saturday night!
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
