nah i rug up for work, its too cold otherwise
anyway its time for me to hit the bed, seing as i have to work tommrow
and i spent most the night on the phone, to my non existant friends
damnit you lazy people, how many times did i take yas places, ime to return favour and they are all too busy :|
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha thought u were looking for a job Ben?
Liz haha - we dont have uniform - first day i rocked up to DoIR dressed really business like - to see everyone else dressed in t-shirt and shorts!
Adam - haha yeah small world
liz; yeh but hes always worn his shirt untucked or a shirt thats too smal with the collar up. aarons been whinging for ages but valere finally layed the smack down and he had to put on a red shirt.
except he was too embarrassed to get changed so he put it on over the top hahaha
how was drinks? would have been nice to go - i had a few when i got back to try and relax from probably the most stressful day ive had ever! :P
Night bel.
Glad to see you have come to the west to whore.
Typing refresh or f5 is so gay in qld
Cheers
ken
Originally posted by Sneeza
Adam - hahah I know I'm always putting his collar down... silly boy
Yeah drinks was ok.... good for a laugh....
I'm sitting here half in PJ's , half in work clothes.... great look!
Looks fine from here:D
Cheers
Ken
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
