  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
night to QLd's i know choclate and keyboards dont mix - just have to see my keyboard at work to know that! :P
Ken i know im as disapointed in me as you are!
Babe , you NEVER disappoint.
Just your presence and ackknowledgement makes my heart flutter...
oh and:grouphug: to niz cos pwpttf wasn't on today.
Cheers
Ken:D :D
yeah he's hiking Ken - thats something im saving to do when im old :uh-huh: cant believe u go all the way to Scottland then hike?
Thanks for the cuddle Ken ..... oh and i felt that pinch on the butt :P
That wasn't me , that was Bel.
Hehee
Long arm of the qld'ers
Cheers
Ken
haha Liz - Troy sent me this ..... Are u a geek quiz ..... its god damn 200 or so questions tho! But one of them was - Do u sometiems go out dressed up as a geek or hold geek parties or something liek that ...... immediately i thought of your little friend :P
oh and the root that u were suppose to get in the carpark too Liz hahaha
Originally posted by Sneeza
hahaha oh yeah those guys....
ken - there were these guys dressed as geeks for a 21st and one asked me for a kiss...
Shit , a geek party.
I woild have fitted right in.
Or am I a nerd ??
Hmmm , wished I could remember. Damn alschiemers.
Where we we again ??
Cheers
Ken:D
