Nooooo James!
hell if that happened in my family!! my mum did scratch the ZX once but i couldnt do much about that!
Do ur family have an old bomb they dont care about? i cant stand it when just because people dont care about dent sin their car they arent careful around yours!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
lol more girls than i get to drive round here anyway...
mmm nah its the door of mums new pulsar, and its my stupid sister, shes got no respect for my car, and she calls me a looser and crap when i went off at her for it, and its not like i could go kick her lancer or anything, cause she just reverses it into things for the fun of it anyway....
i dont remember what time it was - according to my mum yelling at us to be quiet it was 4:30am.
maybe the para? this time. They dont charge you to get in .... and i'll introduce Liz to Brendon that works there - he's a bit of eyecandy haha
:grouphug: Russ - that would be really appreciated if u could .... i would have to give u some money for fuel or something to compensate tho! .... or maybe a $2 dolla haha just kids :P
Hey Bam - bankers yuk! they are liek the taxation dept!
