  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha Cam - i was thinking of ringing up and asking ....... haha wonder if he'll accept a fake one just ot ge this club numbers up :D
brakes good - jammed on them this morning in fact and she seemed to pull up alright - will need the front ones done before long but otherwise A1 ...... yeah i was in la-la land this morning half as sleep in the car on the way to work as usual :zzz:
haha i had an aust post van try and drag me off this morning - now that was funny!!! - he was admiring my car at lights - didnt think much of it - flipping thru CD's lights went green .... didnt notice too busy flipping thru CD's til i heard squeel of his tyres ..... haha i took my time for some reason (unlike me) ..... maybe i was aware of a cop just round the corner ....... the cop car slowed right down took a good look at both of us - well especially my car .... even tho the van was doing a far greater speed than me!! but they obviously decided they couldnt book me so went on their merry way...... shouldve booked the van tho - that wasnt fair!
Originally posted by zanda
just speaking from general experience.
though alas, my care factor for such things is waning.
I have concluded that sodomy is entirely overrated.
man you have completely lost me now!
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
